- Aug 5, 2001
- Mirror space station
I'm building a new rig to play apb:r on. It has to have a 3ghz+ cpu 4x core, nvida graphics card, 8gb of ddr3 ram. I didn't go for the ssd drive cause I did not want to risk a device failure.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119194 - case "sniper storm" by cool master
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148609 - hd seagate (I have had success with this brand)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131636 - Asus M4N98TD EVO (never tried this brand b4, but have heard good things in the past.)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121446 - GeForce GTX 560 (Just going with 1 video card for now I don't play a high res. so no need for 2 cards)
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102019 - Sound Blaster X-Fi Titanium Fatal1ty (the cheap one is outa stock so might as well get this one )
http://www.newegg.com/Product/Product.aspx?Item=N82E16817194054 - ENERMAX PRO87+ EPG600AWT 600W 80 PLUS GOLD Certified (another brand I've has success with)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460 - G.SKILL Sniper Series 8GB (2 x 4GB) (Looking at the memory specs certified for use with the motherboard this was the closest I seen in model##'s I could find even though its not an exact match)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808 - AMD Phenom II X4 955 Black Edition Deneb 3.2GHz (best bang for my buck imo)
Any advice or known problems I want to avoid with this setup?? My main concern is the ram working with the motherboard.
Thanks in advanced for any advice given
