micamica1217 said:
oooooo........pics please.
I still have my ax-478.
mica
Oops , no pictures yet (mabe this weekend) .
Here's what I did ....
I wanted a put a Panaflo 92mm (12H1A , 2850 RPM , 56.8 CFM , 35 DB) on my AX-478 for a long while .
Searched all of Gods green earth for an easy way to do it .
FINALLY found this
92mm to 80mm adapter
Next , I just took my dremel and ground out the inner lip (almost to the outer edge) so that I would get the full flow or the 92mm fan without any blockage .
Bolted acrylic adapter then to AX-478 then put the 92mm fan on top of that and "PRESTO" !!!
Works like a charm .
If you notice at the same site they also have a "120mm to 80mm acrylic adapter " for even a possible better mod .
I decieded to try the 92mm thing first to see how well it would work ; and so far pretty happy with it .
I'll try and take a picture or two of the adapter installed for ya abit later .
But you can easily imagine what it looks like and how easy all this is to do .
As I mentioned before , the HARDEST part was finding a good starting part that was easy to work with , and the acrylic adapter fit the bill perfectly .
*EDIT*
I forgot to mention ...
I did have to cut down long black factory AX-478 fan screws (about 1/2 the original length) since the screws were no longer going "through" the length of the fan , but only through the length of the acrylic adapter of which is only about a 1/2" thick. Then the regular fan mounting screws ( that come with the adapter) were used to fasten the fan to the acrylic adapter itself.
stereo555
