- Sep 4, 2010
High End - Intel
- Processor - Intel Core i7-950 Bloomfield 3.06GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor
- Motherboard - GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58
- Memory - Mushkin Enhanced Blackline 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop
- Heat Sink - Prolimatech Megahalems Rev.B CPU Cooler
- Heat Sink Fans - COOLER MASTER R4-L2R-20CR-GP 120mm Red LED Case Fan x 2
- Case -COOLER MASTER HAF 932 Black Steel ATX Full Tower
- Power Supply - CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
- Video Card - SAPPHIRE Vapor-X 100281VX-2SR Radeon HD 5870 1GB 256-bit
- Hard Drive - Western Digital Caviar Black 1TB 7200 RPM
- Solid State Drive - OCZ Vertex 2 2.5" 60GB SATA II
Total Price: ~$1400
Long time lurker, first time poster. Not sure if this reply is in the right thread since it's more dedicated to updating the buyers guide. Sorry if it is misplaced.
I've been in the market as of recent for a mid to high end build and have been doing lots of research to get the best bang for the buck. This build above is spot on to what I've been looking for but a few hundred bucks out of my max price range. Granted, I've built stupid-expensive machines before, and been quite happy with them...but this will be the first PC I'll have built since being married, and it took a little coaxing to get the wife to go along with a ~$1k build. A little wiggle room is acceptable, but I don't really want to cap out at more than $1100. That being said:
If you had to cut a few corners on the above, what and where would you?
I was thinking of-
1. Changing case for a cheaper one. There are plenty of bone cheap metal boxes out there. As long as I make sure there is adequate airflow, I shouldn't need anything fancy.
ex. http://www.newegg.com/Product/Product.aspx?Item=N82E16811119202
That saves me $90, and it's still a decent case. (If you believe otherwise, or have an alternate solution I'd love to hear it!).
2. GPU. I haven't done enough research on newer cards so I don't have a definitive opinion on them yet. But, I'm not sure I'm ready to drop $400 on one. It does look great, but I'm sure I can save another $100-150 if I choose an alternative that will still perform well.
3. SSD. I've never worked with an SSD before and I've managed fine. I know loading your OS on it makes your machine boot crazy fast, but I rarely turn my boxes off once they're up and going, save for necessary reboots or extended periods of away time. To me, it's an unnecessary $160.
Any thoughts/input/etc would be greatly appreciated. I'm looking to drop the hammer within next week or so, and the above build as I said is right in line with what I want to go with...just with a few tweaks.
Thanks in advance.
