- Jul 7, 2013
Ok here's the situation...
Really tired of AMD's underpowered processors so I am looking for an intel build that will last me quite a while but at the same time spare my wallet from being empty.
I've been eyeing the i5 4690k for a while but not sure if it would be the optimal proc for my needs which is: Playing high end games, video encoding/converting, Audio encoding/converting, Streaming. Since it's been a while since my last intel build I don't know if there is a newer version or which motherboards are compatible with what.
For the motherboard I'd like something that can overclock and runs pretty cool. Bluetooth and usb 3.0 are not a must but would be nice. I'm also thinking about getting a mini itx board but have no experience in them and don't know their drawbacks.
For the ram I already own DDR3 16 gb Patriots that are clocked at 1600. Not sure if they are compatible with intel boards.
For the GPU I already have a 7950. The problem here is that it is pretty huge. For example, if I do go with a mini itx board and a small case I have no clue if it will fit or not. I also am thinking about using an old CM Storm Scout case I have lying around but don't know if they fit there either.
For the PSU I would like a modular one. Something very reliable.
I'm probably gonna use the stock cooler for a while to save money but if you guys have any suggestions on that I'll take them.
So the budget is around 700-800 and that may or may not include a case (depending if my 7950 will fit.) Honestly I'm probably going to buy the parts at my local Frys since its very easy to return defective parts, so please go by retail price.
