- Feb 3, 2012
Hi guys,
Been around the forums and overclocking since the celeron and MMX days, but only recently got into the whole benchmarking thing and decided it was time to build a new machine up with some watercooling headroom, so, here we go.
Case:
Corsair Obsidian 800D
Mobo:
Asus Maximus Extreme IV - Z
CPU:
Intel Core i7-2600K
GPU:
3 x Sapphire Radeon 7970's
RAM:
16GB of Corsair Vengeance 1866MHz
HDD:
2x OCZ Vertex 3 Sata 6 SSD
2x 1TB Western Digital Velociraptors
PSU:
XFX Pro 1250w Black gamer Edition
Optical:
Pioneer 12x Blu Ray Combo Drive
Monitor:
3 x Dell UltraSharp U2410 24" LCD
OS:
MS Windows 7 Ultimate 64bit
Cooling & Monitoring
CPU Block:
EK Supreme HF Plexi EN
Radiator:
1 x EK Coolstream XT 360mm Copper Fins - Single Circuit
Reservoir:
XSPC Acrylic Dual 5.25 with pump inside
Pumps:
Alphacool VPP655 - D5 Pump
Fans:
3 x Scythe Gentle Typhoon 1850RPM - AP15s on the radiator.
3x Corsair 140mm fans around the chassis.
Fittings:
Bitspower compression fittings
Tubing:
Masterkleer 59117 3/8" in red.
Coolant:
Feser Aqua - Ultra Pure Water
Controller & Monitoring:
Aquacomputer Aquaero 5 Pro
Coolant temp monitored before and after radiator.
Lighting:
LED's and a UV inverter so far.
Basic hardware and case...
+ water cooling parts.
Case unwrapped..
Some parts unwrapped...
360mm radiator installed with 3x Scythe GT Ap15's
Temperature monitoring for radiator inlet and exhaust
Installing EK water block on the MOBO.
Some pipes, and mobo installed.
Sata hotswop bays are quite ingenius and lovely to wire up.
Then a cover makes it all neat and tidy.
Ready to power up...
Up and running...
Case:
Mobo:
CPU:
Intel Core i7-2600K
GPU:
RAM:
HDD:
PSU:
Optical:
Monitor:
OS:
CPU Block:
Radiator:
Reservoir:
Pumps:
Fans:
Fittings:
Tubing:
Coolant:
Lighting:
Case unwrapped..
Up and running...
