I am going to upgrade my existing machine. This time, instead of doing the incremental upgrades as I typically do, I am replacing all the major components. This entails over $1K of hardware so I would appreciate others thoughts with respect to what I currently have in Newegg's shopping cart. I do not regularly keep up with the latest hardware developments to feel confident my decisions are good decisions and I will be getting a reasonable bang for my buck. I do not game but I am anal about having a very snappy machine. I always overclock but only to a conservative extent so reliability and stability are not challenged. I also use a lot of of very large PDF files (200-300 Mb) that seems to significantly slow down my existing machine.
The following hardware is what I plan to use:
-Intel i7-6700K
-ASRock Z170 Extreme6
-G.Skill Ripjaws V 16 GB (2X8GB) DDR4 3200
-Samsung 950 Pro M.2 512 GB PCI-Express
I am reasonably confident the 6700K and Extreme6 are good decisions.
I am not so sure that I appropriately chose the memory spec.
The Samsung M.2 PCI-Express drive may be a dumb decision because it will be in place of a 512 GB SATA 850 Pro I already have. The M.2 drive is not worth $350 if it does not provide a noticeable difference.
-Intel i7-6700K
