- Oct 16, 2016
mobo: msi h81m-e33
Ram: ddr4 ballistic 8gb
Gpu: 1060 6gb
Psu: 500w evga bronze certified(just got it today)
I7 4790
Everything is new i just got it barebones and installed a new PSU (listed above).
I tested the PSU with the tester and it works fine.
I'm not sure if the motherboard doesn't support ddr4 ram, thus, I will try Ddr3, though i don't think thats the problem.
I turn the computer on, all the fans spin, but none of my USB connected devices show lights or activity, and then the computer restarts itself and just stays at an empty black screen. Zero activity on the monitor. The computer doesn't beep at all.
I've unplugged SSD, RAM and GPU one by one, didn't make a difference.
I'm not sure the ram fits in the socket in the mobo. Attached is a picture showing the gap in the RAM vs where it fits in. It doesn't sit in the hole. I've been able to snap the clips onto both sides of the RAM but if I remember correct it should sit flush in the gap.
Does ddr3 look different than ddr4 in terms of where that gap is?
Could that be the problem? I honestly have no clue here, haven't built a desktop in a decade.
Gpu: 1060 6gb
I7 4790
