I also plan on doing SLI or Crossfire
You can Crossfire a 7750 now actually. But the 760 would wipe the floor with any hybrid crossfire.
That only says 6 series. There is a link that shows all cards, perhaps its in there? I'm mobile though.. so can't look myself.
I still say you should be looking at a 4670K and a $140 1150 motherboard. If you go AMD the CPU will be cheap but the mobo will be expensive.
There are a few, agreed. But not like Intel where any will do. There are specific models with enough power bits and cooling on them that can be used, whereas with Intel, most any Z77 will be fine, but 990FX and FX CPUs(125W) that pool is a lot smaller and tends to get expensive, at times, closing the gap between price differences. That said, so long as its not a 125W processor, most any board will do.I beg to differ.
There are plenty of good AMD boards for $140 or less.
AMD isnt my thing, but I have seen posts describing otherwise. If you lop off the 2-3 boards that ssjwizard describes in his thread, you are left with some pricey(er) solutions that all but eliminate that gap of $. Then you have to figure... is it worth (for example) $20 to get the AMD or do I get the Intel at that point...My point is though, you'll come out cheaper with AMD overall, no matter the processor.
Of course, assuming that person was right, LOL!
Great deal... talking retail though, and a 125W CPUs.
+1 on the 6300 for gamming, mine game rather well and less investment to cool than the 8350, pair it with a good good card and your ready to go.
