R3NEGADE
- Aug 14, 2015
- Sparta, NJ
So, I just finished building my first computer, super excited . After I got my OS installed (Windows 7 Professional) and my drivers, I ran into some issues. First and foremost, I got a Windows error saying that I had a faulty hard drive. That one was a heartbreaker but an easy fix. I ordered a Samsung 850 Pro 256GB SSD which should arrive sometime next week, problem solved except for the fact that I have to go through the entire setup process again. My second problem starts here. When I opened up my case to take out the faulty drive I noticed the heatsink was wobbling. My best guess is that I installed it incorrectly. I took it off the motherboard as quickly as I could so the thermal compound wouldn't run off the processor onto the motherboard or even worse, into the socket. I didn't reinstall it because I'm unsure how to properly attach it. So, these are my quesitons:
1. How do I properly install the heatsink? It's the stock Intel heatsink by the way. I read on Tom's Hardware that you should put the pins in the lock position and press them into the motherboard in a diagonal fashion (Press the top right and bottom left pins in first, then the same on the other side). Is this the best way to do it?
2. This is probably a no-brainer, but to play it safe I'll ask anyway. Do I need to reapply the thermal compound. As said on Tom's Hardware, I should reapply thermal compound each time I remove the heatsink. Personally I don't think this is necessary but you guys would know better than me.
3. Last one, how long after your new PC is build is it safe to overclock? Yes, I know I can't overclock with the stock heatsink (I'll buy a watercooler later on). My motherboard is capable of it (ASUS Z97-A) so all I have to do is figure out how, but that'll come later on. So, once your new PC is up and running for awhile, would it be safe to overclock, say, three months with it?
Thanks guys!
Thanks guys!
