but i like my antec case lol it had a fan on the back of the motherboard
your awesome
Pretty sure they have nearly the same, dual 120mm intake, back 120mm exhaust, top exhaust (single 200mm on the Antec vs dual 120mm on the Lian Li).
Nothing I've ever built it comes close to Lian Li quality. Not even close. And I've built in Antec, Cooler Master, NZXT, etc.
Warranty on a case? Not much can go wrong there.
Depends on the skill of the guy who puts the water inside the electric box.
If you give a watercooling kit (not a LCLC like Hydro Series) to your Average Joe, you'll witness a fest of magic smoke.
If you give it to someone that likes the hobby and that has read the stickies from the Watercooling section, you'll witn... you'll drool over a beautiful silent beast.
A LCLC isn't usually dangerous, they're pretty sealed and you can't really go wrong with them as long as you don't cut a tube or something.
i think i might go with the h80 then because one of the other reasons i was hesitating with the 3750k was i heard it ran hot and if they help that much it will be good
The 612 should be able to get you to about 4.5GHz. Get the H80 if you want to go higher than that.
The temperature thing with Ivy Bridge has been, IMO, blown way out of proportion. My CPU runs just as hot, if not hotter.
