- Aug 5, 2011
- Coffs Harbour, Australia
Hi guys,
I've just built a new(ish) computer for my boss so his son can play some basic games... And it won't start.
I have used his old case, PSU, DVD drive and 500GB HDD. The new parts are a AMD FX-4100 CPU, ASRock 970DE3-U3S3 Motherboard, 2x Corsair CMV4GX3M2A1333C9 (4GB DDR3 1333MHz) RAM and a Gigabyte GTX550 Ti 1GB GPU.
My problem is I try to boot the Windows that was installed on the drive, and it just bluescreens (as expected). I insert the Windows XP Pro (32bit) disc to try and repair the installation and it gets to the part where Windows is booting off the DVD and it bluescreens.
I figured this could be a 32bit issue (even though I thought that the FX/970 combo was 32-bit compatible), so I plug in Ubuntu 64 bit and try to boot that... It froze on startup (from the USB), both in live mode and when I went to install, both at the same spot, every time. Same thing for the 32bit Ubuntu intaller/live mode.
I can't find my Vista DVD (I have a code but no disc), nor do I have Windows 7 to test it. I'm downloading Windows 8 Release Preview now to test it.
Any other ideas as to why it won't boot? I checked all the plugs, everything is in there right, it's just got me stumped!
