So I made the mistake of falling for the Asus P9X79 Deluxe back in September, and as of now (December), I have yet to have a functional PC using this board. I am absolutely, totally, at a loss as to what the problem could be!
Build Detail:
Board: Asus P9X79 Deluxe (RMA'd x2)
Chip: Intel Core i7-3930K 3.2 GHz (RMA 'd x2)
Cooling: Corsair H100
Power: CoolerMaster 1200W Pro 80 Gold (RMA'd x2)
RAM: 1st Try: 16GB of Corsair Vengence - 2nd Try: 16GB of GSkill Ripjaws Z
Vid: EVGA GeForce GTX670
Boot Drive: Intel 520 SSD 240GB
Data Drive: Hitachi SATA 6gbs 2TB HDD
Case: Cooler Master HAF 932 Advanced
So on the first power-on, my system actually "did" show video & attempt to POST. It got about 1-min in & shutdown on it's own ... never to boot again. So I did all the typical system checks, ending with a bare bench test ... nothing. All the system would do is run in a continuous loop of spinning the fans for a second & flickering some LED's.
2nd board shows up from Asus; it was missing a heatsink lug out of the box ... so right back it went (no system test with this board).
3rd board shows up from Asus & looked good, so into the build it goes. Still, I get the exact same results ... "00" Q-Code, no beeps, a solid red CPU_LED, and NO POST. Yep, I even updated the BIOS.
A call back to Asus results in the attention now being on the CPU (Intel Core i7-3930K 3.2 GHz). So it get's RMA'd. New one arrives brand new in the box, install it, & same result.
Next call back to Asus results in the Power Supply being the focus (CoolerMaster 1200W Pro 80 Gold) ... even though my Thermaltake PS Tester says it's A-OK. So, I RMA the Power Supply. New one arrives, install it, & same result.
Call back to Asus results in yet another RMA for the board ...
Build Detail:
