- Jun 28, 2009
- Virginia Beach, VA
I've never built before. I've had a good teacher help point me in the right direction. Just posting the build we've come up with to have some help tweaking. The most strenuous thing it will do for now is WOW, Diablo III, Adobe Photoshop. I will be overclocking...looking for between 3.6-4.0. Any advice would be appreciated.
Antec Three Hundred Black Steel ATX Mid Tower Computer Case
OCZ StealthXStream OCZ700SXS 700W ATX12V / EPS12V SLI Ready CrossFire Ready Active PFC Power Supply
GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard
Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor Model BX80570E8400
XIGMATEK Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-4GBPK
HIS H489F1GP Radeon HD 4890 1GB 256-bit PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drives
OCZ OCZTFRZTC Freeze Extreme Thermal Conductivity Compound
2x Scythe S-FLEX SFF21E 120mm Case Fan
I've chosen several optical drives off of newegg, and they keep running out of stock. Any input into good drives (DVD burner and lightscribe) would be appreciated. In reality its going to wait until I'm ready to buy the components around the 25th, that way I know its in stock. I'm sticking with Newegg for anything possible largely because of how new I am at this and how easy they make everything as far as returning dead parts and such. Thanks for the help.
Antec Three Hundred Black Computer Case Gaming - Newegg.com
Buy Antec Three Hundred Black Steel ATX Mid Tower Computer Case with fast shipping and top-rated customer service. Once you know, you Newegg!
www.newegg.com
Used - Very Good: GIGABYTE GA-EP45-UD3P LGA 775 ATX Intel Motherboard - Newegg.com
Buy Used - Very Good: GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard with fast shipping and top-rated customer service. Once you know, you Newegg!
www.newegg.com
Intel Core 2 Duo E8400 3.0 GHz CPU Processor - Newegg.com - Newegg.com
Buy Intel Core 2 Duo E8400 - Core 2 Duo Wolfdale Dual-Core 3.0 GHz LGA 775 65W Processor - BX80570E8400 with fast shipping and top-rated customer service. Once you know, you Newegg!
www.newegg.com
www.newegg.com
XIGMATEK Dark Knight II SD1283 Night Hawk Edition CPU Cooler with Stealth Aerospace Industry Thermal conductive ceramic coating ALL intel AMD IVY BRIDGE compatible - Newegg.com
Buy XIGMATEK Dark Knight II SD1283 Night Hawk Edition CPU Cooler with Stealth Aerospace Industry Thermal conductive ceramic coating LGA1150 Haswell Compatible with fast shipping and top-rated customer service. Once you know, you Newegg!
www.newegg.com
G.SKILL 4GB (2 x 2GB) DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-4GBPK - Newegg.com
Buy G.SKILL 4GB (2 x 2GB) DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-4GBPK with fast shipping and top-rated customer service. Once you know, you Newegg!
www.newegg.com
HIS Radeon HD 4890 Video Card H489F1GP - Newegg.com
Buy HIS Radeon HD 4890 1GB GDDR5 PCI Express 2.0 x16 CrossFireX Support Video Card H489F1GP with fast shipping and top-rated customer service. Once you know, you Newegg!
www.newegg.com
Western Digital Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive Bare Drive - Newegg.com
Buy Western Digital Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive Bare Drive with fast shipping and top-rated customer service. Once you know, you Newegg!
www.newegg.com
OCZ OCZTFRZTC Freeze Extreme Thermal Conductivity Compound - Newegg.com
Buy OCZ OCZTFRZTC Freeze Extreme Thermal Conductivity Compound with fast shipping and top-rated customer service. Once you know, you Newegg!
www.newegg.com
Scythe S-FLEX SFF21E 120mm Case Fan - Newegg.com
Buy Scythe S-FLEX SFF21E 120mm Case Fan with fast shipping and top-rated customer service. Once you know, you Newegg!
www.newegg.com
