- Mar 4, 2003
Nice shot of the wire mess behind my desk.
IC7 Max3 with TDX block and 9700 with DD block
Whole set up, BIX mounted on the rear, push/pull 120mm fans
Slightly blurry BIX mounting shot.
More BIX mounting. (the cheapo vinyl hose kinks if i use the second hole drilled out. I need to get some more tygon.
another mounting shot.
Hydor L30 and Tline shot, that white stuff is dried water-wetter from a resivor leak
TDX mounted.
Kink by the 9700 the tubing has turn sharply to make it to the t-line
T-line ending comes out the top of the case, I cut a hole in the grill for the top fan and added a rubber grommet like on the back.
Scale shot of the CM stacker in all its glory.
Comments? Likes?
