Hi,
I need some advice. I’m looking for a case option(s). I have an ATX Mobo (ASUS X99-DELUXE/U3.1 LGA 2011-v3), Intel Core i7-5820K Haswell-E 6-Core 3.3 GHz (over clocked), EVGA 1080Ti (overclocked), custom water cooling loop with a 3 - 120mm fan radiator (XSPC RS360) (and it doesn't fit, pic below). I have a PrimoChill CTR Hard Mount Phase II High Flow D5 Enabled Reservoir and Pump - 120mm . It’s made for mounting to the back of the case but with the amount of space in the case, I have it mounted on a bracket to the floor.
I have a fairly large case right now (NZXT Phantom PHAN-001BK Black Steel / Plastic Enthusiast ATX Full Tower) but a ton of room it taken up by the 5.25 bays and it’s not really built for having a radiator in the case… I had to remove a lower HD bay to put the pump and res in.
I have a Blue Ray Player but… I so rarely use it, I’m thinking I’ll forgo the CD bays next time.
I should say that though I have 5 drives right now, when I buy a case, I'm moving to a large NVMe SSD and a few standard SSDs. Probably will not get a standard drive again.
Anyway, the actual questions are:
1) What case should I buy?
2) Should I drop to a duel radiator instead of a triple?
3) Should I keep my case but drop to a Duel radiator, so it fits?
As you can see, the radiator sits partly on my blue ray player and it doesn’t look nice there. The case is built to have the hoses leave the case from the back, up and into a slot where it would connect to a duel radiator on top that is covered with part of the case (refer to case specs if you’re interested). I’m not really interested in having the hoses leave my case.
