So awhile back my CPU was over-heating so I bought a Hyper 212+. I loved it, was a drastic 20 degree difference over old heat-sink, but I wasn't able to put the fan on it due to my CPU socket being RIGHT under the top of my case. Well, I upgraded mobos/CPUs and have a 3570K now.
Well, when I run OCCT at full load, it INSTANTLY goes from 30 degrees to 60, and hovers around there. Is this typical? I OC'd it to 4.4GHZ and I got the same result. Instant 60, then aims between 60 and 70 slowly growing. I'm wanting too (And thinking about) putting the push/pull system on the Hyper 212 because I mean, it needs it. But I don't have the plastic clips it came with.
(My case has the rear fan about 4 inches from the Hyper 212, and the top fan is MAYBE 2 inches from it, so I'm wondering if maybe it will even really boost the temp.)
My original question is: Why does this new CPU get so hot, so quick? Like it goes from 30 to 60-70 the instant I start it, and calms down to 40 as soon as it ends. Is the core temp just being too sensitive and registering the voltage increase as direct temperature?
