- Jun 6, 2002
Interesting, but there is a lot of information that is missing. Basically, from what I gathered, is that they are combining solid state storage and RAM into one unit. What they don't explain (or what isn't clear) is how either performs. I'm assuming the volatile RAM will perform at or near current systems, but how fast can it dump it into non-volatile memory? If it was instant or near instant (less than a few seconds), I could see some uses. You could greatly lower the UPS needed to keep a computer "safe" if it didn't need to actually be running. Use a very small battery (much like RAID cards have) that can detect power loss and keep the system on long enough to move it to non-volatile memory. No need to power the whole system at that point.
Honestly, it just sounds like using hibernation, except it doesn't use the hard drive. Neat concept, but we need more data.
EDIT: Another idea that was not mentioned. Would it be possible to instead use the non-volatile RAM for other uses, such as data that does not change (libraries, etc)? This would free up system memory and leave data that needs to change frequently to the components that are made for that purpose.
I understand what you are explaining now and that makes a lot more sense. I was thinking of it in terms of "a SSD here combined with RAM here". Instead, it is more like "one cell of RAM here with one cell of SSD next to it". Basically, it is like millions of SSD circuits in parallel. Since they would all be accessed at the same time, it would be instant, or near instant.
It would be the same as putting an infected computer into hibernation, though. It isn't any different except for the speed at which it stores the information.
