- Jan 12, 2012
JDay it's all about how far you want to go and how much you want to play. There is nothing wrong with pushing the FSB further but just to insure that the the memory being OC'ed isn't the cause if and when you run into instability, yes you may want to drop it down to a lower multiplier for now. That way you can find stability on the Cpu first then you can always bring the memory back up. It just makes it easier to pin point instability issues when really pushing.From this point could i just look at bumping up the multiplier and add to the vcore for stability as needed? Or should i continue to keep scaling things like i have, and if so should i maybe drop my intial memory clock speed back from 1600, to maybe 1333 or lower?
