Hey Guys,
First time posting but been coming here for a long time. Im having a problem with my computer. When i built it about a year ago i was able to OC my CPU to about 3.096GHz by changing the Bus speed to 129MHz seeing as the multiplier is locked at 24x. i was running it like this for about 10 months with no problem full system stability, running every system stress test i can find. At that time i had a COOLER MASTER Hyper 212 and was just running my WD 1.5 TB HDD. still running windows 7 64-bit.
About 2 months ago i ran into a good deal at Frys and i got myself a Corsair H50 Water cooler and a Corsair 60GB SSD.
I Installed the H50 correctly and hooked up the SSD. did a clean install of Windows 7 64bit. Hard Drives set under AHCI and reinstalled all the drivers using newest ones. figuring i might be able to get a bit more power out of the CPU with the water cooling i decided to bump up the bus speed to 130MHz. tried to booth into windows and i got BSOD. i brought it back down to 129MHz and tried getting into windows and again a BSOD. i tried messing with the cpu voltage and APU voltage going up at .005 increments nothing. IT wouldnt let me boot into windows unless i had the MHz set to 103 or less. All Adjustments were done manually using the bios. I also messed with the settings
CPU Load Line Calibration
CPU/NB Load Line Calibration
CPU Current Capability
CPU/NB current Capability and CPU Power Phase Control
Any help will be appreciated. Thank you
System Information
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1
Processor: AMD A6-3500 APU with Radeon(tm) HD Graphics (3 CPUs), ~2.4GHz
Multiplier: 24x
Bus Speed: 103.0 MHz
Motherboard: Asus F1A75-V PRO (BIOS V.2206)
Memory: 8192MB RAM Corsair CMX8GX3M2A1600C9 (2X 4GB)
Card name: NVIDIA GeForce GTX 550 Ti
Hard Drive: Corsair CSSD-F60GB2 ATA Device
Hard Drive: WDC WD1502FYPS-02W3B0 ATA Device
System Information
Multiplier: 24x
