- Apr 20, 2004
- JAX, Mississauna
Maybe this is the reason why some of the workers are slow. Using myself as an example, when I'm trying to get X mhz oc stable ill set the Cpu V run prime, it fails 1 worker, I bump the Cpu V, it runs 2 hours and passes. Maybe it is because it is "just enough" voltage to keep the workers happy and working for 2 hours. I'm going to do an experiment when I have time and see if upping the Cpu V at a known stable oc will increase and/or have the amount of tests completed more inline with one another.
"Drake" I think you are on to something there. When you said low Vcore, it reminded me of that post I put up in one of those long test threads of mine. I benched Cinebench at one Vcore and then at a higher Vcore and the bench result went greater when I increased the Vcore. Such result lead me to believe at one point I was just barely using enough Vcore to run the bench at all.
RGone...
