- Feb 7, 2005
- North West UK
I am looking to get a new heatsink+fan for my Sempron3000 (SoA). I want to get from the following site as have store credit to cash in. I want something that is quiet yet decent cooling so I can push my cpu and still have relatively low temp under load (by low I mean 45C under load).
I used to manage this on my old AthlonXP2000 on air, but the fan was a 7500rpm 6cm coolermaster and the fins on the sink were so thin I needed to clean it every month to keep cool as dust killed it (despite fan filters). Even a thermaltake smartfan2 on full belt with a 60mm-80mm fan adapter didn't cool as well despite similar airflow (80mm fan at 5000rpm pushed around same as 60mm at 7500rpm), I find fan adapters are crap though. It sounded like a hoover inside my machine so don't want to go back down that road as am attached to the relative quiet of the stock cooler. I don't want to spend load though so am considering the following
I like the look of this as used to love my orb sink on my ancient duron800MHz as got some great cooling with relatively low airflow (hence low speed and noise). Nice and compact and worked well and this looks similar
http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=170222
If not this looks cheap but the sink is alu with copper slug base (I like copper on cpu die as much higher heat tranfer yet alu looses it easier so want alu fins), I can always change than fan to get the noise/cooling ration right.
http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=129198
Or anything else from
http://www.scan.co.uk/Products/Products.ASP?CatID=10&Category=Coolers&Thumbnails=yes
that is £15 and under is considered. Any suggestions welcome. Thanks.
