- Thread Starter
- #21
Ok now, At 4.9 I ran Prime Blend for 2 hrs. I have my voltage in my bios set to 1.425 V (display in cpuz shows a max voltage of 1.464v, but most often under load it shows 1.444v in cpuz)
(When bios was set to 1.410v , it failed in prime.)
I will try to lower my voltage to below 1.425 but higher than the 1.410v it failed at and check for stable.
My max temp spike was 89C , but 99% of the time it was 78-82C.
Idle is below 40C
What might be some advice for further tweaking (beside trying to bring the voltage down a little) , or trying to get higher than 4.9?
OR based on my voltage and temps, would you recommend I don't go any higher?
Idle is below 40C
