- Jan 12, 2015
I just got a new i5-7600k to add for my benching. I'm using a ASUS iX Apex (z270) with the lastest BIOS installed. I know I should have tested it before I de-lidded it but...
I have search online for my problem but no option fixed the problem ;-( I have taken this i5-7600k to 5.4GHz @1.6v and it has not broken 80c yet
So here's the problem --> The MB will not boot with memory speed SET above DDR4-2133. If I set it to DDR4-2400 (or any speed above 2133) I get an error code 25. I've looked this up and it is the most common with a CBB on the cpu. If I increase the Voltage to the IO and/or SA I get a error code of 3E. I've gotten by with setting the memory to 9-8-8-28/160 1T @2133. Has anyone had this problem with a i5-7600k - will this go away if I use my SS unit/dice?? Should I buy another??
Thank You
Thank You
