First guys, thank you for your site, and letting me join. I have planned my system, and am at the point of "waverin" back and forth on the motherboard.
I am ordering the e8400: http://www.newegg.com/product/product.asp?item=N82E16819115037
I am using a single video card only, and yes I selected the HD3870 over the 8800GT.
The memory I selected is the OCZ ReaperX HPC 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000): http://www.newegg.com/product/product.asp?item=N82E16820227277
The case I am using is the Antec Nine Hundred Black Steel ATX Mid Tower: http://www.newegg.com/product/product.asp?item=N82E16811129021
My budget for a motherboard is $230.00 maximum. At this time I do not plan on running crossfire. I do want the ability to overclock the processor and memory for sure, and easily if possible.
I am completely open to suggestions, and would greatly welcome them from you guys. I thank you for your time.
I had looked at these motherboards, but if they are not good, or there is something better, please by all means tell me:
ABIT IP35 Pro LGA 775 Intel P35 ATX Intel Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813127030
GIGABYTE GA-X38-DS4 LGA 775 Intel X38 ATX Intel Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128080
DFI LP UT P35 T2R LGA 775 Intel P35 ATX Intel Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813136037
EVGA 132-CK-NF78-A1 LGA 775 NVIDIA nForce 780i SLI ATX Intel Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813188024
What I do not want to do is get into a logistical nightmare of bad boards (I understand it can happen), and BIOS fighting with a brand new board if possible. But, thats what I wish anyway...
Open for suggestions guys, and once again, thank you.
