hello everyone! i am a new user in this forum and wanted to hear the expert's idea on my work
i have a desktop computer that i am using for video editing, little 3d modeling, games and desktop work. since my demands from the computer are pushing it to its limit.. i am always short on computing power lol
i want to redo my overclock, what i did so far is stable but i am having a problem with overclocking my dram - whenever my memory is on more then its original speed (1066) i get blue screens/errors concerning memory issues. i feel that the issue with the memory (will get to that in a sec) is mostly about timing, i dont know anything about timing and havnt tried to mess with it yet.
here are my specs, some i typed myself and the most i copied from everest, i think that everything is here:
case: antec 300 full powerd up with fans
ps: hec cougar 700w 700cm
mb: asus p5q pro turbo (intel P45 chipset)
cpu: q9550 (12mb cache)
cpucooler: arctic cooling something (dont remember the name, a huge block with good fan that i've picked).
spd: 2 * OCZ Reaper HPC OCZ2RPR 1066 2G (5-5-5-15 @ 533 / 400mhz, 4-5-5-13 @ 333mhz, 3-4-4-10 @ 266mhz)
2 * G Skill F2-8500 CL5- 2GBPI-B (5-5-5-15 @ 533 / 400 mhz, 4-4-4-10 @ 266mhz)
gfx: Sapphire Radeon HD 6850 1gb oc , gpu 950 mhz, mem 1175mhz)
audio: asus xonar d2x
storage: 1 * segate 1tb , 1 * hitachi 500mb
bios settings:
cpu ratio: 8.5
fsb: 444
pcie: 101
fsb strap to nb: 333
dram: 1067
cas#: 5
cas# to ras#: 5
ras# precharge: 5
ras to active precharge: 15
other memory setting - auto
dram static read control: disabled
dram read training: disabled
dram oc charger: disabled
ai clock twister: lighter
ai transaction booster: auto
CPU Voltage: 1.27500 V
CPU GTL REF: 0.63x
CPU PLL: 1.740 V
FSB Term.Volt: 1.360 V
NB Volt: 1.500 V
SB PCIE: 1.500 V
SB Volt: 1.300 V
DRAM Voltage: 2.280 V
CPU Clock Skew: Normal
NB Clock Skew: Normal
load line calibration: enabled
pcie spread spectrum: disabled
cpu spread spectrum: disabled
cpu margan enhancment: performance
cpu c1e/cpuid/cputm/disabled bit/everything: disabled
onboard audio/firewire: disabled
power: s1 only
all disks on ahci
currently i think that my dram cpu ratio is 10:8 but i dont know if its good ? my cpu is stable on 3.78, each core has a different temp but on load it gets to max 59-60 and on normal use the temp is around 34-38 (depend on which core). gpu temp is on 46 idle 68-70 full load.
i know that my memory is a big issue, 8gb with two sets of different vandors, all of the sticks needs 2.1v on default, the timing is very simular but not the same @ 544 - ocz 5-5-5-15-24-54-3-6-3-3, g. skill 5-5-5-15-24-51-3-6-3-3 (CL-RCD-RP-RAS-RC-RFC-RRD-WR-WTR-RTP)
i've read a little about UNDERclocking ram for better performance as well which should allow to tighten the timing ? but the moduls that i'm having should be kicking 1150 with no problem with the right timing (i dont know what to try other then the default settings).
anyway, any help will be appreciated!
ps: sorry for my english
thanks!
bios settings:
cpu ratio: 8.5
fsb: 444
pcie: 101
dram: 1067
cas#: 5
cas# to ras#: 5
ras# precharge: 5
CPU GTL REF: 0.63x
CPU PLL: 1.740 V
NB Volt: 1.500 V
SB PCIE: 1.500 V
SB Volt: 1.300 V
power: s1 only
all disks on ahci
thanks!
