New pc advice
asg102
What will computer be used for mostly:
-Graphic design
-Web design
-Mild 3D
-Video editing
-Audio editing
-Mild Gaming I mostly only play counter-strike and games that sponsors send out for me to test
-Run multipule gaming servers at LAN
I also plan to overclock it a little.
Which case would you think is better and if I got the Cavalier would the 350 watt power supply be sufficient? Also I am not sure if thats a good powersupply I am getting, is there another would you would recommend in that price range. Another thing is the cooling fan for the cpu do you know any better in that price range or do you think that ones good enough.
Any advice is welcome! :D
Code:
1x Cooler Master Wave Master Case without Power Supply
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=11-119-023[/url]
OR
1x  Cooler Master Cavalier 3 Silver/Blue ATX Mid-Tower Case With Side Window
LINK: [url]http://www.newegg.com/app/ViewProductDesc.asp?description=11-119-058&depa=1[/url]
2x Xper Aluminum Hard Drive Cooler with two 60mm Cooling Fan, SILVER
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=11-999-034[/url]
2x CoolerMaster Blue 80mm Neon LED Fan
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=11-999-051[/url]
1x COOLER MASTER Round, 18-Inch, Floppy drive cable, Booted, 2-Connector
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=12-103-302[/url]
2x COOLER MASTER ROUND, 18-Inch, ATA133/100/66 IDE Cable
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=12-104-225[/url]
1x ABIT "IC7-G MAXII ADVANCE" i875P Chipset Motherboard for Intel Socket 478 CPU
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=13-127-152[/url]
1x BFG nVIDIA GeForce 6800 Video Card, 128MB DDR, 256-Bit, TV-Out/DVI, 8X AGP
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=14-143-020[/url]
1x Antec 480W Power Supply with Blue LED Fan
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=17-103-914[/url]
1x Intel Pentium 4/ 3.2 GHz 800MHz FSB, 512K Cache, Hyper Threading Technology
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=19-116-165[/url]
2x Geil Value Series 184 Pin 512MB DDR PC-3200
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=20-144-305[/url]
1x NEC 1.44MB Black Internal Floppy Drive
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=21-152-005[/url]
2x Western Digital Raptor 36.7GB 10,000RPM SATA Hard Drive, Model WD360GD
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=22-144-200[/url]
1x Logitech Elite Keyboard USB/ PS/2 104keys
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=23-126-114[/url]
1x Logitech Blue Performance Optical Mouse PS2/ USB
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=26-104-151[/url]
1x Lite-On Black 16X DVD-ROM, Model SOHD-167T
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=27-131-118[/url]
1x NEC 16X Double Layer DVD±RW Drive, Black
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=27-152-032[/url]
1x Creative Labs Sound Blaster Audigy2 ZS Platinum PCI Sound Card
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=29-102-163[/url]
1x Arctic Silver Premium Silver Polysynthetic Silver Thermal Compound
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=35-100-007[/url]
1x Cooler Master JET 4 CPU FAN for Intel P4 478
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=35-103-142[/url]
You should def. go with the antec power supply that you listed. Also why not got the prescott 478, its practically the same price if not ten bucks cheaper. Another thing is your hs, don't waste 45 bucks on that thing, either get a thermalright xp90, or xp120. If newegg doesn't have 'em in stock go to heatsink factory. Also instead of getting two smaller slower raptors to run in raid 0, just get the larger 76 gig raptor, as it has a better seek time and would end up being faster than two smaller slower ones in raid 0. I also doubt you will need the hard drive cooler if you put the hardrives in the front where they normally go, becuase there is a case fan up there.
Michael
SOrry to tired to read your system stuff. All I can say is go into cyber deals(towards bottom of oc forums. And look for the 59 case and a deal on raptors was just reported. SO check them out.
