batboy said:
I think Flyingrat is onto something there. I'm guessing the vcore is a typo.
The 533 bus is easy to explain, this allows an upgrade path to a Prescott (which is cheaper to build than the Northwood due to it's smaller core, so Intel makes more profit) if you only have an older motherboard that don't support HT or 800 bus CPUs.
You know, Batboy, I was thinking on the lines of that before - on the no-HT/no-800 capability. That would be the first logical explanation I would think of. But any motherboards I could think of that would fit this description are the 845PE, 845E, and 850E for these. And of those, only the 845E (I think) did not have HT capability. But as far as I know, none of these chipsets or motherboards built with them ever had any support for the voltage spec that the Prescott carried - they wouldn't seem to work at all! And if you did somehow get them to work, chances are good that the VRM circuitry would be bludgeoned to death by the Prescott within days!
My only guess after that was so OEMs could conduct a bit of "PC line engineering" with it.
You see, the 2.8A, as I know first hand, isn't particularly fast. Even the old 2.8B beats it handily, and the 2.66 gives it a good run for its money. All while making less heat (mine does 38C idle, 54C full load with a Zalman 7000 AlCu at stock speed) and wearing on the motherboard less. But we all know Intel wants to make as many .09 micron CPUs as they can; they're cheap to build, and they have to pay for those fabs somehow! So, making as many Prescotts as possible, even low-end ones allow them to make more return. OEMs then have a low-performance option to put in their PCs. Intel and the OEM are both happy.
The best example of this I can think of is Dell's Precision 360 line. The baseline CPU is the 2.80A. The 2.8E is a $120 upgrade. It's a rip-off upgrade, but from a performance standpoint, the 2.80A is bordering on abysmal for its clock speed, so to some folks, it'd almost be worth it! The upgrade continues on up the line - 3.0E, 3.2C/E, 3.4C/E, and P4EE models.
Fortunately, this price gouging allows me to buy the CPUs off my company for cheap, while upgrading from an external source saves the company money. It's about the only good that comes out of it, really.
My 2.80A is currently running 3.33 at stock voltage, and it seems to perform well with a bit of its bus restriction alleviated. My dumpy MSI motherboard with no voltage or memory divisor controls is what's holding me back; the CPU at 3.33 runs at 42C idle and 58C full load. Enough to heat my room pretty easily.
As stated before, I'll let everyone know once my buddies get their 2.80As up and running and how well they tweak.
I'm beginning to think I'm the only person on this forums that has or ever will have 2.80As!
