- Aug 27, 2003
- Mississauga, Ontario
Hi. the system in my rig (mobo DFI Ultra D with the S939 and Opteron) is screwed.
it's been like that for a long while, it won't start up, so i have to keep it on forever, but last night I just did a normal reboot like I do once a month or so, and it wouldn't get anywhere.
Now, I finally shut it down, but when I tried my trick of plug/unplug, when I finally get it to start, it doesn't really start, it just caughs and the red lights blink and the fans only start going mildly, and nothing much happens at all.
Before I shut it down, everything was working perfectly.
Now, I want to upgrade my computer anyway, probably to the Gigabyte UD3 and 8150CPU, but, if I get the modular PSU from Corsair (the one I want is the TX750 or something similar), will it be able to run with my current system until I'm ready to upgrade the rest?
I cannot afford to get mobo/cpu and ram right now which is the minimum I would have to get in order to run (keep video card the same, radeon 3870), but I want a good PSU, and am just wondering if this PSU (TX750) has the same connectors and will power my Ultra-D (if indeed that is the problem).
Anyhow, before I shut it down, on reset, the furthest red light would blink like 5 times, then the rest would go off one by one like usual and the computer sounded as if it restarted, but no screen, no nothing. Once I shut it down, I could never get it to run again, not even with my two year old trick of plugging the power cable in and out until it catches power.
Thank you.
Thank you.
