- Jun 16, 2004
Here is what I have put together::
Cases (Computer Cases, ATX Form)
Lian-Li 12-Bay Silver Aluminum Case With side window, Model "PC-65"
Item# N82E16811112024
CD/DVD Burners (RW Drives)
NEC 16X Double Layer DVD±RW Drive, Black w/ Software, Model ND-3520A, OEM
Item# N82E16827152038
Hard Drives
Seagate 80 GB Barracuda 7200RPM SATA with NCQ Hard Drive, Model ST380817AS, OEM
Item# N82E16822148040
Memory (System Memory)
CORSAIR XMS Xtreme Memory Speed Series, Xtra-Low Latency 184-Pin 1GB(512MBx2) DDR PC-3200 w/ Heat Spreader, Model TWINX1024-3200XL - Retail
Item# N82E16820145522
Motherboards - AMD
DFI "LANPARTY UT nF4 Ultra-D" NVIDIA nForce4 Ultra Chipset Motherboard For AMD Socket 939 CPU -RETAIL
Item# N82E16813136152
Fortron Blue Storm 500W ATX12V V2.0 Power Supply with 120mm Fan, P4 and AMD ready, Model "AX500-A" -RETAIL
Item# N82E16817104934
Processors
Crackin' Deals
AMD Athlon 64 3200+, 512k L2 Cache, The Only 64-bit Windows Compatible Processor - Retail
Item# N82E16819103483
Video Cards
eVGA nVIDIA GeForce 6800 GT Video Card, 256MB GDDR3, 256-Bit, Dual DVI/TV-Out, PCI-Express, Model "256-P2-N376-AX" -RETAIL
Item# N82E16814130215
The only question is I have a winchester as my processor -- Ive heard dirt on the fact that it holds you back from doing things like overclocking and adjusting the timings on your RAM. With this motherboard, I dont want to be held back much.
I understand the fact that the newer processors aren't as overclockable -- but if someone had to pick what would it be?
Thanks,
Matt
Hard Drives
Motherboards - AMD
Processors
Crackin' Deals
Video Cards
Thanks,
Matt
