captsulu2004
- Mar 1, 2018
I thought I would share my new rig with you guys. I will be making changes to this in the future. I just wanted to build the system and get it done in the meantime.
Specs:
Thermaltake View 31 case(includes 3 riing 14 fans top mounted)
EVGA SuperNOVA 650 G3 PSU
MSI X99A GAMING PRO CARBON MoBo
16 gb G.SKILL Ripjaws 4 Series DDR4 2400 Ram
Intel Core i7-5820K Haswell-E 6-Core 3.3 GHz(O/C @ 4.2)
EVGA GeForce GTX 970
EK Fluid Gaming 240
Kingston HyperX 120 SSD
ADATA XPG 512 NVME
Seagate Baracuda 3tb
upHere 5-Pack Wireless RGB LED 120mm Case Fans
I do want to make changes. I want to raise the res, add a basement for the psu, cover the back panel openings in the case with plexi, and swap out the soft lines for hard tubing.
The CPU, Ram, and GPU are all existing parts, everything else is the upgrade. The easiest thing for me to do to go from a AOI cooler to a custom was to get this EK 240 all aluminum kit. They are supposed to be releasing aluminum fittings for hard tubing, when they do I will switch the tubing out. I would also like to add another rad(maybe a 360) and mount it in front where I have this 240 and mount the 240 at the top.
I would LOVE to upgrade my GPU and water cool that as well but that will have to wait till the pricing fiasco is over with. Until then, I will make a custom lighted backplate for my little ol 970 to spruce it up.
If you guys can think of anything please do tell. And feel free to critique my build, I love getting new ideas from it.
Specs:
EK Fluid Gaming 240
ADATA XPG 512 NVME
