- Apr 27, 2008
Greetings all...I could really use your input regarding my component selection, especially the pump. Thanks for the help.
System:
Intel Core 2 Duo 6550 2.33Ghz
nVidia 8800gt (g92)
Lian Li pc-v1000
Requirements Priority:
First - Noise Level - I work next to this machine all day long.
Second – aesthetics - this machine is the center piece of a custom built-in desk and shelf unit. This is also goes with priority #1 – any excessive vibrations are passed along the lian li case, through the wheels to the wooden support shelf and eventually the desk. So low noise and low vibration are essential.
Third Performance - Good temps at mild overclocks are the goal. But extreme low temps and super overclocks are not needed.
I will be cooling the cpu and the gpu, but not the chipset or hard drives. I have built several air-cooled system prior to this build and have been prepping for this water cooled build for some time.
Here is what I have selected so far
CPU waterblock – alphacool NexXxoS Bold socket 775
GPU – XSPC Razor 8800 gt (g92)
Rad – Black Ice Stealth 240
Tubing – 3/8 ID 1/2 OD (still selecting the type/brand)
Fittings – 3/8 barbs
The D5 and DDC pumps receive a lot of attention and recommendations, but based on what I have read, and the order of my requirements, I do not think the D5 is the right choice. I have not been able to find much information about the smaller pumps such as those from xspc and alphacool.
Here are the pumps I’m looking at…any input and feedback on the components and pump are greatly appreciated.
Danger Den CSP-MAG 12V (still some left at Petra’s)
http://www.petrastechshop.com/dadencs12vop.html
Alphacool AP700
http://www.alphacool.com/shop/Pumps/AP700-centrifugal-pump-12Volts--648.html
AlphaCool AGB-Eheim 600 Station II Pump
http://www.arcticmod.com/computer-m...-II-pump-12-volt-1/2-3/8-1/4-inch-systems.htm
XSPC X20 400
http://www.xspc.biz/400pump.php
DDC with XSPC - Laing DDC Top
http://www.jab-tech.com/XSPC-Laing-DDC-Top-pr-4124.html
System:
nVidia 8800gt (g92)
Lian Li pc-v1000
Alphacool AP700
XSPC X20 400
