Hey well I recently upgraded from a 7 year old laptop to a very cheap computer build that i bought of ebay which i thought would be good enough to do the job on the games i wish to play.
I've heard very little about overclocking before and when i just got the new computer, but i knew it could get more performance out of my games so i really wanted to give it a crack. So I got the computer and installed Catalyst 11.8 Drivers (Side note had a bit of trouble with the computer with the hard drive not being reconised so took it to the shop and they put the driver 11.8 on it for me) didnt read to much up on it and mucked around with the catalyst GPU unlocker program (stupid thing of me) and thought all would go well...
Now with ALOT of research done i've discovered alot of things about overclocking so i've got safe zones for me GPU and CPU but i would like to get your oppions on them to. Sorry for the long text but i'll give you my specs now and see what you think with the benchmarks i use.
Mobo: AsRock H61
CPU: Intel i5 2500K
GPU: Sapphire HD 6850 1GB
RAM: 8GB
HDD: 1TB Sata3 WD
PSU: 650W (not sure brand lol :/)
Cooling System: All stock with no case fans
At the moment i've only done some changes, haven't fully got my overclocking at what i think is good enough for me.
GPU 935/1000 voltage 1150.
CPU 2.5ghz 1100 GT Frequency stock voltage's. (Dunno what GT Frequency acutally does, some insight would be good)
Benchmarks i use are Furmark And Unigine Heaven DX11. Furmark and Unigine Heaven for Core Clock and just Unigine Heaven for Memory Clock.
I will give you my results and see what you think and also some advice on what drivers would be best and the most stable cause when i tried to install the 12.3 drivers it kinda crashed and benchmarked very low :/.
Unigine Heaven
55.8 FPS, 1406 Score, Max Temp 59c
API:directX11, Tessellation: Disabled, Shaders: High, Anisotrory: 4x, Stero 3D; Disabled, Anti-Aliasing
1920x1080 full screen
FurMark
score 2339, 25fps, 74c max, 1920x1080 full screen, anti-aliasing off, Dynamic background, burn in.
Havent benchmarked cpu yet cause dunno the programs or benchmarks yet.
safe temps
GPU 75-80c
CPU 65c
Could i go higher you think?
Games i wish to play are Crysis2, Guild Wars 2, Call Of Duty, Battlefield 3.
Mobo: AsRock H61
CPU: Intel i5 2500K
RAM: 8GB
HDD: 1TB Sata3 WD
Unigine Heaven
FurMark
safe temps
GPU 75-80c
CPU 65c
