Hi there
I'm going to buy the R9 290x and I'd love to water cool it. I am, however, new to it all. I've been watching hours of guides the past week so I've got a pretty good idea of what to do.
I've got the following components:
Mobo: ASUS Maximus V Formula
Case: Corsair 550D
HDD: 500GB WD HDD
HDD#2: 4TB WD RED
SSD: 240GB Intel Solid-State Drive 520 Series
CPU: I7 3770k
RAM: 32GB 1600 MHz (some corsair ones)
PSU: Corsair AX1200W gold
GPU: well that's a tricky one. I am going to buy the R9 290X which I would like to have water cooled. I also have a 7950 (had two for litecoin mining, but one was RMA'ed and refunded. I am going to replace that with a R9 280x)
I would like to have all the GPU's as well as the CPU water cooled, but is that even possible? First of all, is it possible for me to fit the three GPU's in the case/mobo? I think it is, seeing as there are 3 16x PCI-E slots, but the lower one is very close to the PSU, will this be a problem?
Anyway, is it "possible" to do a custom water cooling loop in the 550D without having to make permanent changes to the case? as in having to cut stuff out. I also have 3 HDD/SSD total so I do need one of the harddrive bays.
Water cooling them all might be a bit too expensive, so I might just go with the 290x and the 280x, but what components would you say that I should get? As I said this is my first experience with water cooling, so I don't know much.
So far I'm thinking of going with the following:
http://www.ekwb.com/shop/ek-fc-r9-290x-acetal-nickel.html
and
http://www.ekwb.com/shop/blocks/vga...00-series/ek-fc7970-matrix-acetal-nickel.html
Haven't decided what CPU block, reservoir and pump I need (possibly a reservoir and pump in one??), so I am very open to suggestions. I'm also open for suggestions for the GPU blocks, these are just the ones I've looked at so far.
Anyway I hope someone is able to help me. I greatly appreciate your time, thanks
Kind regards
Alexander
Case: Corsair 550D
HDD: 500GB WD HDD
HDD#2: 4TB WD RED
CPU: I7 3770k
and
Kind regards
Alexander
