- Apr 7, 2012
- Near Toledo, OH
I have yet to do a custom loop, but am planning on doing an all out build with the release of Broadwell/Skylake ($6000ish).
1) It looks like the blocks have drilled holes where you "plug" your barbs into. Are all of these holes universal (it does not matter if your going to run a 3/8" or 1/2" tube).
2) How do you mount radiators to the case - especially the vertical ones.
3) Can you mix sizes of tubing w/in a build or is this just not recommended?
4) Recommend cases where you can install 3-4 Rads?
Thanks, and I know I can google some of these, but it is sometimes nice to just a personalized answer from exp. users.
