- Nov 6, 2018
Hi all,
First of all hello, I'm new to messing with OC'ing, please feel free to throw me pointers!
I was fortunate enough to win one of the 8086k's in intels comp a few months back and have finally found enough $$$ to buy a motherboard and ram (corsair lpx 3200) to get it going. I've paired it with my previous Noctua NH-U14s which seems to cope fairly happily.
I'm now trying to find the best settings for my system. I'm not really interested in truly OC'ing this CPU as I cannae afford a new one or a new cooler to cope. At the moment I'm just trying to get my head around the classic with/without asus MCE debate.
I've tried a few combo's so far:
1) XMP enabled and MCE enabled (all other settings default):
Max CPU = 5 ghz
Avg CPU under load = 4.3 ghz
Max Core temp = 66-70oC
Avg Core temp under load = 55-60 oC
Max Core voltage = 1.399v
Avg Core voltage under load = 1.175v
2) XMP enabled and MCE disabled (all other settings default)
Max CPU = 4.6 ghz
Avg CPU under load = 4.1 ghz
Max Core temp = 65oC
Avg Core temp under load = 60 oC
Max Core voltage = 1.25v
3) XMP enabled and AI O'Cing enabled
Max CPU = 5.2 ghz
Avg CPU under load = 4.8 ghz
Max Core temp = 91oC
Avg Core temp under load = 70 oC
Avg Core voltage under load = 1.375v
My question is really which of 1 and 2 should I really be running with? I realise option 3 is pushing things too far with my current cooling. Option 2 seems very safe but I would prefer it if I could hit the 5ghz turbo once in a while. What would you all advise? Is running with MCE enabled going to put too much of a strain on CPU and cooler?
All advice much appreciated!
Cheers!
Max CPU = 5 ghz
Max CPU = 4.6 ghz
Max CPU = 5.2 ghz
Cheers!
