- Feb 25, 2013
- Spring Hill, Florida
- Thread Starter
- #21
SWTOR, like any other game, is not RAM intensive. You don't need more than 8GB of RAM, you probably don't even need that much.
The GPU and motherboard have nothing to do with each other overclocking wise. If you want to overclock your CPU, then get a unlocked CPU and a Z77 board. If you don't want to overclock, then you can get a locked, cheaper CPU and get a B75 motherboard. Again, this does not have any effect on your GPU choice in any way.
what criteria do you use when you pick out a motherboard? how can you tell which ones are better then the others?
would you mind helping me with a new build / overclock setup?
single gpu amd radeon
i'll need to purchase a copy of windows
