- Jan 10, 2006
- Boston, MA
I'm new to linux and need some help.
I recently downloaded Fedora Core 3 and cannot for the life of me figure out how to get Fedora to use my wireless card (Gigabyte 802.11g PCI WLAN Card).
*Note: Fedora detects the NIC on the PCI bus when I use the following code: [root@localhost Module]# lspci | grep RaLink
I've done quite a bit of research but I always get lost when I see the code I'm supposed to use (ex. [root@localhost Module]# make, [root@localhost Module]# make install) Both of these commands to not respond when I press enter in the command terminal.
I have also tried to follow the instructions for ndiswrapper (forcing linux to recognize & use the windows driver for the NIC).
I've even tried to simplest approach of manually configuring the network and forcing it to recognize the wireless card, but none of the options seem to work. I always get an error when I try to activate it.
I'd appreciate any help/insight that you might have.
Thanks!
Thanks!
