I am of course new and the forum is great! I did a couple small changes but my temp is very high so would appreciate some recommendations. I have all stock fans. 2 on the case, one for the psu and one on the amd. I hope these screen shots will help but i can take more if needed...
60c isn't too bad on a stock AMD cooler. What motherboard do you have?
The CPU temp that reads 70 is the motherboard cpu temp. They are usually off by up to 10 degrees in one direction or the other. The core temp is the one you want to worry about.
If your motherboard has heatsinks on the VRM then put a small fan right over the top of them and you will not only cool the VRM but the drop in VRM temp will cause the CPU to drop temp to. You could drop the temp as much as 10c
. . . The CPU temp that reads 70 is the motherboard cpu temp. They are usually off by up to 10 degrees in one direction or the other. The core temp is the one you want to worry about.
I agree that the core temp is the critical one if the sensor is calibrated reasonably accurately but I think most FX users have concluded they usually report core temps 10-15c on the cool side. I would therefore recommend looking at both with an eye to not letting the CUP socket reading exceed 70c and the core temp not exceed 60c.
That little fan cools down the VRM a whole lot and cooling down the VRM means the CPU will be cooler as well. Since the VRM is what supplies the CPU with its power it also transfers its heat to the CPU via traces that connect the 2 together.
Doing this could drop your CPU temp anywhere from 4-10c the hotter your VRMs are right now the bigger the difference will end up being.
