i would recommend atleast buying clamps for everyone connection (and also putting them on) but, if you go with 7/16" ID tubing, some won't use clamps everywhere, since its such a tight fit, or some will use just zipties. again, at the least, by enough. 12 feet is fine. will leave you with some extra
so you open the excel sheet. you are on the INTERFACE tab. at the top you see tubing. click inside the box of the diameter you are using, an arrow box will appear at the end of the box, click that, and select the number of feet from the drop down menu. repeat for every box.
on cpu: D-Tek Fuzion V2 Quad Nozzle
on gpu: Swiftech MCW 60
on rad: Switech MCR-320
Pump: now this one could have been confusing. the swfitech mcp655 is the Laing D5 Vario, setting 5, on that list, so select that.
reservoir: just choose one.
you are done!
now i dont know whats up wtih this version and all the "needs retesting" garbage. maybe an older version is more accurate, maybe they are the same.
