Hey guys, so I just noticed a wonderful amount of algae growing in my EK nickle plated GPU block. I'm going to assume that everything now has algae growing in it even though most of my tubes and reservoir appear fine. It seems like everyone is mixing their distilled water now with some biocide or some sort of agent to prevent growth and other things. What's the best on the market these days?
What's the best tubing out there that will last several years of usage and cause small plastic stuff to build up on the walls of the tubing? I'm looking to keep everything in the clear color category.
I'm using a Swiftech MCP655, XSPC Raystorm Copper CPU block, two nickle plated copper GPU blocks, a Swiftech single rad and a black ice dual rad, and a Swiftech Micro V2. I also have two sets of nickle plated brass quick disconnects, and another 2 sets of steel quick disconnects. The QDs do have corrosion going on when you disconnect them, so I'm guessing something is not happy in this loop as far as material stackup is concerned.
Thoughts?
Thoughts?
