Wow! I'll trade you my ethernet over power adapters
got a SteelSeries H Circumaural Wireless Headset enroute and no mention of send back either.
I still got nothing! You can't put a price on that.
They're sending some awesome stuff every now and then between the ethernet switches, wireless routers, and powerline adapters.
I recently found that 3TB NAS drive they sent me about this time last year. I need to find a home for it...
This is actually the second mobo they've sent me, although this one is much higher spec than the previous one. Ordinarily I would have declined it but my main desktop has been showing signs of age over the last few months. It's an Athlon X3 on an old AM2+ board running DDR2 memory. I picked up a cheap dual core pentium which benchmarks faster than it for $60, I already have suitable fast DDR3 memory, SSD 120GB, 2TB SATA III drive and PSU. Now that I think about it the only thing in the case which wont be a review item will be the CPU!
Better question: How many don't have compatible hardware and "review" it anyway?
Wouldn't be any less accurate than the PSU reviews
"Uhh...the box is pretty and it came with a bunch of extra cables. I plugged it into a power supply and an LED lit up. 5 Eggs!"
Or what wouldn't surprise me if it also happened -
"The thing is a POS! I don't have a compatible CPU, but I tossed some RAM and an old graphics card in it and it didn't even post! 1 star!"
Well this mobo at least will be used in a constructive way. I teach a class in introductory electronics to a bunch of High School students. We've gone through the usual passive components, active components and building a couple of simple soldered kits (all of which the kids got working... in some cases after significant rework!). I've introduced them to PC architecture and the components and we'll be using this mobo to build a PC and install a variety of OSes. For most of the students it'll be the first time they've seen anything that isn't a branded off the shelf computer, and the first time they'll have seen anything that isn't Windows or OS X. They are all on board with the idea that home builds may not save them money but will allow them to control the quality of the components. Once built and operational I'll be putting it through its paces and using the students input and perceptions in the final review. Should be an interesting process.
So, you bought a low end locked chip to test this overclocking motherboard out?Gigabyte Z97X Force LGA 1150 mobo on its way, I was thinking of upgrading my desktop anyway
