Not much has been happening in the Donor Advisory Board. Discussion of deadlines and client side benchmarking is the latest, but the discussion has died. Here is where it ended:
Deadline discussions have revolved around shortening the deadline to exclude the Virtual box core trick that allows i7 2600Ks to appear to be 12 core machines to the AS. Unfortunately that would also mean many slow 12 core machines wouldn't make the deadline either.
kasson said:Re: Deadlines
Postby kasson » 08 Aug 2011, 15:31
How long will it be before we switch to a client side benchmarking system?
Good question and not something I have the answer to. As currently structured, the client-side benchmarking would come from a development effort that Dr. Pande manages.
I am reluctant to use -bigbeta to denote higher-performing machines; I think we already have a donor perception that beta work units have higher points yield (something we try to avoid), and I'd rather not cement this opinion. It's important to us that we have beta testers primarily motivated by a desire to help out more than to earn maximal points.
The question of where to put the deadlines is tricky. For 6903 and 6904, each trajectory really becomes useful to us only when it gets to about generation #20. We'd love to have some trajectories out to 50+, but it would be more important to have all the runs have 10+ clones to generation 20 than to have 3 run/clone pairs to generation 50. That said, having all the run/clone pairs to generation 10 means that none of them are useful to us yet. That's the kind of calculation we're doing. While in theory it would be possible to automatically modulate project allocation according to how many clients of what capacity are available, it requires both additional sophistication on the AS and additional information regarding client performance that we don't currently possess. (In addition, when you think about balancing this out across all the FAH projects, it starts to get really complicated.)
Hopefully that gives you a flavor of what we think about science-wise when setting project/machine capabilities. We're also trying to balance all the donor concerns that you're likely more familiar with.
User avatar
kasson
Pande Group Member
