- Feb 25, 2013
- Spring Hill, Florida
Hello everyone,
I've been piecing together my next build. My last rig was really good to me I haven't kept up with the newer tech. My last pc was a I5 3570k with 8gb ram and an EVGA SC 780.
I was getting less then stellar performance on the one game that mattered (SWTOR.) Everything else it owned... With ease! Strange : /
Initially I had a OC 7970... After installing my 780 (per benchmarks) my performance went up about 30%!!! I was excited. I log into SWTOR, hop into a raid... To my dismay my FPS was exactly the same! 16 man raid... In the heat of battle fps = low 20's. (At best.)
This time around i'm going with the I7. For the GPU I was thinking R9 290x. From what i've read (stock) it out performs the 780 and it's 200 bucks less! The price for the 290x is killer... Especially since it was around 600 bucks nearly a year ago.
I'm going to double the ram to 16...
750 PSU... Should that be enough head way? The 290x is a power hog? How can you determine the amount of juice you need to run your pc? Would it be looking up the max wattage / draw for each of your components?
Thank you!
Thank you!
