I recently got an nf7-s, and am wondeing about a few bios settings..
First of all here are my spec's so far..
Nf7-s
2500 mobile barton
TR slk800A w/ smartfan II
2X512 Corsair Value select, stock timings 2.5-3-3-7 @ 2.7, but will boot 200fsb fine with 2.5-3-3-5 @2.6
I currently have them @ 220X6, 3-3-3-11 @2.9v, memtesting... but I can boot fine @ 230fsb as well, and seem to get around the same amount of errors in memtest as @ 200.. about 2 errors every 2-3 passes...
Running abit's 26 bios.. just to test the mobo and cpu out, cause I just got them.
Here are the questions I have for now..
I should have agp and fsb spread spectrum disabled, correct?
What about CPU thermal-throttling? Disabled as well?
I shoud be running CPU interface enabled? Even if I can get less memtest errors @ higher fsb with it disabled?
Any other settings you guys think I should take a look at?
Thanks!!!!
Nf7-s
2500 mobile barton
Thanks!!!!
