Before I start, sorry if this would go in Hardware/Sound.
Hey, guys. I just bought a Razer Tiamat 7.1 headset, and I'm running into some problems with using it. To make the bass work in 7.1, the FAQ says you have to put it in 7.1 mode (within the sound control panel) which I did fine. The other thing it tells you to do, is a problem however. It says that I need to go into the Sound Control Panel, then click on my headset and go to 'Enhancements' then select 'Bass Boost'. I don't have Bass Boost.
That's what my menu looks like. It's all properly plugged in to my computer, because I've checked multiple times and it even tells me on the Properties menu. I don't yet know if it could be a faulty headset, but I don't think so because when I put it into 2.1 the bass works fine.
Thanks a ton for any help =)
Bahooki
P.S. Here's the Razer FAQ. It's the one at the very bottom.
http://www.razerzone.com/tiamat/en/faq
Bahooki
