asusmobogtx
- Dec 1, 2012
No signal on my monitor when i plug it into my GTX 670
I spent all friday trying to set up my pc. My mobo has two pci-e slots , one is 3.0 x 16 the other one is 2.0 x 4 . My monitor shows : no signal when i plug it into the gpu {bios loads and OS loads , gpu fan functions too.
When i plug my monitor into mobo onboard graphics everything works properly.
Last night i tried another thing , i removed my gpu from pci-e 3.0 x 16 slot to the other slower slot which was pci-e 2.0 x 4 and everything worked like a charm. Graphic card works , signal is on and everything is running. The only problem is that this slot limits my cards power.
I need your wisdom guys ! Is there a faulty part in my build so i can just REM it or is there a solution to fix it somehow ?
My system :
Mobo ASUS P8B75-M LE, Socket-1155
CPU i5 2500k
RAM Crucial DDR3 BallistiX Sport 1600MHz 8GB kit(4GBx2)
PSU XFX ProSeries Core Edition 550W PSU
SSD Crucial v4 SSD 2.5" 128GB SATA 2.0
GPU EVGA GeForce GTX 670 2GB PhysX CUDA
My system :
CPU i5 2500k
