- Jun 3, 2004
Alright, I'm having a little difficulty with overclocking my XP-M 2500, I'm kinda low on cash so I'm not trying to push it to far just around 200x11.
My specs are:
XP-m 2500
Abit NF7-s v2.0 (the one with blue and purple DIMM slots)
512mb cheap mushkin pc3200
slk47u with 92mm panaflo
Right now I can boot into windows with 200x11 with core voltage from 1.55-1.7 but even at 1.7 I'm getting an error in prime95(Torture Test,Blend) within 30-45 minutes. DIMM voltage is still at default. From what I've seen, I didn't think I'd need to push past 1.65v to goto 2200. I just want to make sure there isn't something I'm missing before I try raising the core higher.
Case temp is in the mid-20's and cpu idle is mid 30's usually.
Also the Abit manual said to place DIMM starting in DIMM3 and moving down, system wouldn't even turn on with it in DIMM3, booted right up in DIMM1.
Any help would be much appreciated.
My specs are:
XP-m 2500
