To create a signature, click on Quick Links at the top of the page and Edit Signature. You may have to wait up to one hour after making your second post in order to have access to this feature as the forum is set up that way to cut down on spammers.
There is a built in forum tool for attaching images with your posts. First, use Snipping Tool in Windows Accessories to crop and save the image to disc. Then click on the Go Advanced button at the bottom of any new post window and that will bring up the Advanced post mode. Click on the little paperclip icon at the top and that will load the file browser/upload tool and the rest will be obvious.
Have you stress-tested your overclock with Prime95 blend? If not, you need to do so to make sure you are truly stable. You need to be able to pass the blend test for at least 2 hours to conclude you are truly stable. Always have HWMonitor open on the desktop when you are doing this to monitor core and CPU temps (the latte may show up as one of the TMPINx lines in the HWMonitor interface). Don't let the CPU temps exceed 70c for the safety of the processor. Coret temp readings on the FX CPUs tend to be inaccurate as they typically read about 10-15c too cool.
