I've been trying to find spec's for Northbridge coolers. I've only run into a couple of these and knowing the mounting hole spacing is never mentioned. It just seems either "it has holes" or it "doesn't have holes".
Well, if it has holes, then is spaciing a standard? I had an MSI board where I *estimated* the spacing to be 45mm from pictures. Now I have a Gigabyte board and have measured the spacing to be 52mm. Is 52mm=2.047" a standard spacing then?
It seems odd that the hole spacing wouldn't be mentioned. So, that at least implies they are "all" the same.
What can anyone tell me please?
