Hello,
I build my first custom loop and not getting any increase in overclock. One caveat that this is between two different systems, so why model of CPU/MB is the same the actual CPUs are different samples. I wander if there is anything I can improve with my loop or it's just different between CPU samples, Details below:
Custom loop system:
AIO system:
I have two, both with Asus X99 Delux, X5960 and 64GB G'Skill 3000 RAM. One with Corsair H110i GTX, another with Thermaltake Water 3.0 Ultimate.
Performance:
Both AIO system achieve 4.6GHs stable with RAM at 2400. One system is in my office which is air conditioned and it never crashed, The other system is in my non air conditioned home and crashed couple of times on very hot summer days,
My Custom Loop system achieve basically the same performance - 4.6GHz stable. On 4.7 GHz AIDA64 detects hardware failre but only on FPU test, Otherwise I can absolutely anythig at 4.7. But 4.8GHz crashes Windows.
As far as temperatures Cistom Loop CPU runs 7 to 10 C cooler on anything. However under AIDA64 FPU test temperature shoots to above 90 in couple of seconds and hardware failure (worong result of calulation) is detected,
I'm looking for suggestions how to debug/improve my cooling loop.
Thanks,
Vitali Fridman
Custom loop system:
- Asus X99 Delux MB
- Intel 5960X CPU
- 32 GB Corsair Dominator Platinum RAM
- Corsair AX1500 PSU
- EK-FB ASUS X99 Monoblock
- EK-XRES 140 DDC 3.2 PWM Elite Pump/Reservuar Combo - I replaced 140mm with 400mm reservuar
- EK-CoolStream XE 480 radiator
- 2 meters of 1/2" tubing
AIO system:
Performance:
Thanks,
Vitali Fridman
